Ana içeriğe geç
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: adım 1, 2 resimden 1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: adım 1, 2 resimden 2.
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 2, 1 resimden 1.
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 3, 3 resimden 1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 3, 3 resimden 2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 3, 3 resimden 3.
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 4, 3 resimden 1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 4, 3 resimden 2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 4, 3 resimden 3.
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 5, 3 resimden 1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 5, 3 resimden 2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 5, 3 resimden 3.
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 6, 2 resimden 1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: adım 6, 2 resimden 2.
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 2,941
