Ana içeriğe geç
Nerf N-Strike Elite Strongarm Main Spring Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Strongarm Main Spring Replacement, Main Spring: adım 1, 1 resimden 1.
    • Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
  2. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 2, 1 resimden 1.
    • From the base, lift the action and the trigger.
  3. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 3, 1 resimden 1.
    • Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
  4. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 4, 3 resimden 1. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 4, 3 resimden 2. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 4, 3 resimden 3.
    • Unscrew screws (2) from the cylinder rotator mechanism.
  5. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 5, 1 resimden 1.
    • Remove the air plunger and the spring from inside the chamber.
  6. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 6, 3 resimden 1. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 6, 3 resimden 2. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 6, 3 resimden 3.
    • Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
  7. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 7, 3 resimden 1. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 7, 3 resimden 2. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 7, 3 resimden 3.
    • Replace the spring.
    • The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
    • Tip: If dry, use a little vegetable oil on the O-ring before putting it back.
  8. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 8, 1 resimden 1.
    • Return the plunger to the spring chamber.
  9. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 9, 2 resimden 1. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 9, 2 resimden 2.
    • Screw the cover back onto the cylinder rotator.
  10. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 10, 1 resimden 1.
    • Place the spring chamber and the Nerf bullet cylinder back into the base.
  11. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 11, 2 resimden 1. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 11, 2 resimden 2.
    • Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
  12. Nerf N-Strike Elite Strongarm Main Spring Replacement: adım 12, 1 resimden 1.
    • Secure the cover and the charging slide with the 12 screws.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Robert
192 İtibar
1 Kılavuz yazıldı
4 Yorum
Where can I buy a replacement spring?
mike580358 - Yanıt
you can get a replacement or an upgrade spring at the website www.nfstrike.com
NEW CHANNEL -
When I put it back together it did not work
autisteck - Yanıt
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
tiderfish - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 59
Her zaman: 16,290
