Ana içeriğe geç
Nerf N-Strike Firestrike Firing Trigger Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: adım 1, 1 resimden 1.
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 2, 2 resimden 1. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 2, 2 resimden 2.
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: adım 3, 1 resimden 1.
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 4, 2 resimden 1. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 4, 2 resimden 2.
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 5, 2 resimden 1. Nerf N-Strike Firestrike Firing Trigger Replacement: adım 5, 2 resimden 2.
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: adım 6, 2 resimden 1. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: adım 6, 2 resimden 2.
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jong Wan Kim
422 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G6
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 2,990
