Ana içeriğe geç
Nerf N-Strike Firestrike LED Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Firestrike LED Replacement, Blaster Casing: adım 1, 1 resimden 1.
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nerf N-Strike Firestrike LED Replacement: adım 2, 2 resimden 1. Nerf N-Strike Firestrike LED Replacement: adım 2, 2 resimden 2.
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
    FixBot'a Sor
    Yorum Ekle
  3. Nerf N-Strike Firestrike LED Replacement: adım 3, 2 resimden 1. Nerf N-Strike Firestrike LED Replacement: adım 3, 2 resimden 2.
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
    FixBot'a Sor
    Yorum Ekle
  4. Nerf N-Strike Firestrike LED Replacement, Remove battery cover: adım 4, 1 resimden 1.
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    FixBot'a Sor
    Yorum Ekle
  5. Nerf N-Strike Firestrike LED Replacement: adım 5, 2 resimden 1. Nerf N-Strike Firestrike LED Replacement: adım 5, 2 resimden 2.
    • Slide out the two AAA batteries using your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: adım 6, 2 resimden 1. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: adım 6, 2 resimden 2.
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
    FixBot'a Sor
    Yorum Ekle
  7. Nerf N-Strike Firestrike LED Replacement, Laser Assembly: adım 7, 1 resimden 1.
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
    FixBot'a Sor
    Yorum Ekle
  8. Nerf N-Strike Firestrike LED Replacement: adım 8, 3 resimden 1. Nerf N-Strike Firestrike LED Replacement: adım 8, 3 resimden 2. Nerf N-Strike Firestrike LED Replacement: adım 8, 3 resimden 3.
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
    FixBot'a Sor
    Yorum Ekle
  9. Nerf N-Strike Firestrike LED Replacement, LED: adım 9, 2 resimden 1. Nerf N-Strike Firestrike LED Replacement, LED: adım 9, 2 resimden 2.
    • Pinch the clips holding the laser beam casing to the circuit board with your fingers. Slide off the casing revealing the LED.
    FixBot'a Sor
    Yorum Ekle
  10. Nerf N-Strike Firestrike LED Replacement: adım 10, 1 resimden 1.
    • Use a soldering iron to heat up the two connections holding the LED to the circuit board. Remove the LED.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Hayes Kimball
742 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G6
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 3,571
