Ana içeriğe geç
Nerf N-Strike Firestrike Laser Trigger Replacement
Neye ihtiyacın var
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Remove battery cover: adım 1, 1 resimden 1.
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      FixBot'a Sor
      Yorum Ekle
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 2, 2 resimden 1. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 2, 2 resimden 2.
      • Slide out the two AAA batteries using your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Blaster Casing: adım 3, 1 resimden 1.
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 4, 2 resimden 1. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 4, 2 resimden 2.
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      FixBot'a Sor
      Yorum Ekle
    3. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 5, 2 resimden 1. Nerf N-Strike Firestrike Laser Trigger Replacement: adım 5, 2 resimden 2.
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      FixBot'a Sor
      Yorum Ekle
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: adım 6, 2 resimden 1. Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: adım 6, 2 resimden 2.
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jong Wan Kim
488 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G6
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 2,179
