Ana içeriğe geç
Nerf N-Strike Firestrike Wire Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Firestrike Wire Replacement, Remove battery cover: adım 1, 1 resimden 1.
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    FixBot'a Sor
    Yorum Ekle
  2. Nerf N-Strike Firestrike Wire Replacement: adım 2, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement: adım 2, 2 resimden 2.
    • Slide out the two AAA batteries using your fingers.
    FixBot'a Sor
    Yorum Ekle
  3. Nerf N-Strike Firestrike Wire Replacement, Blaster Casing: adım 3, 1 resimden 1.
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nerf N-Strike Firestrike Wire Replacement: adım 4, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement: adım 4, 2 resimden 2.
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
    FixBot'a Sor
    Yorum Ekle
  5. Nerf N-Strike Firestrike Wire Replacement: adım 5, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement: adım 5, 2 resimden 2.
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
    FixBot'a Sor
    Yorum Ekle
  6. Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: adım 6, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: adım 6, 2 resimden 2.
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
    FixBot'a Sor
    Yorum Ekle
  7. Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: adım 7, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: adım 7, 2 resimden 2.
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
    FixBot'a Sor
    Yorum Ekle
  8. Nerf N-Strike Firestrike Wire Replacement, Laser Assembly: adım 8, 1 resimden 1.
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
    FixBot'a Sor
    Yorum Ekle
  9. Nerf N-Strike Firestrike Wire Replacement: adım 9, 3 resimden 1. Nerf N-Strike Firestrike Wire Replacement: adım 9, 3 resimden 2. Nerf N-Strike Firestrike Wire Replacement: adım 9, 3 resimden 3.
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
    FixBot'a Sor
    Yorum Ekle
  10. Nerf N-Strike Firestrike Wire Replacement, Wire: adım 10, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement, Wire: adım 10, 2 resimden 2.
    • Pinch the clips holding the circuit board to the laser assembly and remove the circuit board.
    FixBot'a Sor
    Yorum Ekle
  11. Nerf N-Strike Firestrike Wire Replacement: adım 11, 1 resimden 1.
    • Desolder the wires from the circuit board.
    • The positive wire is attached at the lower left, while the negative wire is attached at the middle of the bottom.
    FixBot'a Sor
    Yorum Ekle
  12. Nerf N-Strike Firestrike Wire Replacement: adım 12, 2 resimden 1. Nerf N-Strike Firestrike Wire Replacement: adım 12, 2 resimden 2.
    • Use a soldering iron to melt the solder attaching the wires to the circuit board.
    • The positive lead is attached at the middle right of the board, while the negative lead is attached at the bottom right of the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hayes Kimball
742 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G6
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 1,228
