Ana içeriğe geç
Nerf N-Strike Maverick Catch Spring Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Maverick Catch Spring Replacement, Use the Teardown Guide to Open the Gun: adım 1, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  2. Nerf N-Strike Maverick Catch Spring Replacement, Remove Large Spring: adım 2, 1 resimden 1.
    • Remove the larger spring from the catch mechanism.
    FixBot'a Sor
    Yorum Ekle
  3. Nerf N-Strike Maverick Catch Spring Replacement, Remove the Catch Mechanism & Spring: adım 3, 1 resimden 1.
    • Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
    • The catch spring has a tendency to bounce away when removed.
    FixBot'a Sor
    Yorum Ekle
  4. Nerf N-Strike Maverick Catch Spring Replacement, Replace the Catch Spring: adım 4, 1 resimden 1.
    • After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
    • If you are unable to find an exact replacement, one may be fashioned out of a pen spring.
    FixBot'a Sor
    Yorum Ekle
  5. Nerf N-Strike Maverick Catch Spring Replacement, Putting the Catch Mechanism Back: adım 5, 1 resimden 1.
    • Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael Walker
193 İtibar
1 Kılavuz yazıldı
Ekip
University of Maine, Team 1-2, Diaz Fall 2014 University of Maine, Team 1-2, Diaz Fall 2014 üyesi
UMAINE-DIAZ-F14S1G2
3 Üyeler
3 adet Kılavuz yazıldı
1Rehber Yorum
do you have a spare catch spring the whole catch mechanism and spring
cowboybebop6968 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 69
Her zaman: 8,289
