Ana içeriğe geç
Nerf Recon CS-6 Main Spring Replacement
Neye ihtiyacın var
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Magazine: adım 1, 1 resimden 1.
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      FixBot'a Sor
      Yorum Ekle
    2. Nerf Recon CS-6 Main Spring Replacement, Remove Visible Screws: adım 2, 1 resimden 1.
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      FixBot'a Sor
      Yorum Ekle
    3. Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: adım 3, 2 resimden 1. Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: adım 3, 2 resimden 2.
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      FixBot'a Sor
      Yorum Ekle
    4. Nerf Recon CS-6 Main Spring Replacement, Remove Plunger Cap: adım 4, 1 resimden 1.
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      FixBot'a Sor
      Yorum Ekle
    5. Nerf Recon CS-6 Main Spring Replacement, Remove Slide Screws: adım 5, 1 resimden 1.
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      FixBot'a Sor
      Yorum Ekle
    6. Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: adım 6, 2 resimden 1. Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: adım 6, 2 resimden 2.
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      FixBot'a Sor
      Yorum Ekle
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Spring: adım 7, 2 resimden 1. Nerf Recon CS-6 Main Spring Replacement, Remove Spring: adım 7, 2 resimden 2.
      • Pull the spring out the back of the gun.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Asad Qureshi
595 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G14
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Where can you buy replacement springs from?
Tom Hallam - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 44
Her zaman: 6,608
