Giriş
The plunger works with the main spring to launch the dart. The o-ring creates a tight seal to stop air from leaking out when the main spring is compressed. This allows for a more powerful shot.
Neye ihtiyacın var
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Remove the screws on the plunger cap.
Tug the plunger cap off.
Pull the gun apart at the middle seam.
Pull the remaining half of the plunger out the back of the gun.
Use tweezers to lift the O-Ring out of groove.
Replace with new O-Ring.
Optional: add a small amount of a lubricant safe for the O-Ring such as petroleum jelly.
Bir başkası bu kılavuzu tamamladı.
My priming bar is stuck how do I fix this?
Ethan - Yanıt
