Neye ihtiyacın var
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Remove the screws on the plunger cap.
Tug the plunger cap off.
Lift trigger up out of the gun.
From here, the trigger or the trigger spring can be replaced.
Bir başkası bu kılavuzu tamamladı.
