Giriş
If any part of the trigger assembly breaks, this guide will show how to remove any problematic areas. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
Neye ihtiyacın var
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
Bir başkası bu kılavuzu tamamladı.
