Ana içeriğe geç
Nerf Vortex Vigilon Slide Replacement
Neye ihtiyacın var
    1. Nerf Vortex Vigilon Slide Replacement, Removing the slide screws: adım 1, 1 resimden 1.
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      FixBot'a Sor
      Yorum Ekle
    2. Nerf Vortex Vigilon Slide Replacement, Removing the slide pieces: adım 2, 1 resimden 1.
      • Lift both slide pieces off of the gun.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cara Pew
932 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G6
5 Üyeler
2Kılavuz Yorumları
Ok so the slide is removed now what? It's still stuck
amanintights1981 - Yanıt Paylaş
i was thinking the same thing
Christina TheTurtle - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 2,708
