Ana içeriğe geç
Nerf Vortex Vigilon Slide Replacement
Neye ihtiyacın var
  1. Nerf Vortex Vigilon Slide Replacement, Removing the slide screws: adım 1, 1 resimden 1.
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Nerf Vortex Vigilon Slide Replacement, Removing the slide pieces: adım 2, 1 resimden 1.
    • Lift both slide pieces off of the gun.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cara Pew
911 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G6
5 Üyeler
Bir Yorum
Ok so the slide is removed now what? It's still stuck
amanintights1981 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 2,252
