Ana içeriğe geç
Nerf Zombie Strike Crossbow Trigger Spring Replacement
Neye ihtiyacın var
  1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: adım 1, 1 resimden 1.
    • There are 19 1.0 cm screws in total.
  2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: adım 2, 1 resimden 1.
    • Separate each part of the Nerf crossbow.
  3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: adım 3, 1 resimden 1.
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: adım 4, 1 resimden 1.
    • Take the broken spring off of the trigger.
  5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: adım 5, 1 resimden 1.
    • Replace it with the new spring you bought at your local hardware store.
  6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: adım 6, 1 resimden 1.
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Bucklin
61 İtibar
3 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-12, Diaz Fall 2014 University of Maine, Team 1-12, Diaz Fall 2014 üyesi
UMAINE-DIAZ-F14S1G12
3 Üyeler
Bir Yorum
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 3,600
