Giriş
If water drips out of the coffee maker, the brewing unit may be defective. The interaction of the capsule, brewing unit and "pyramid plate" is very sensitive, small changes in tolerance cause leaks at the capsule. The brewing unit may have an crack, or the "pyramid plate" that punctures the capsule may be heavily full with debris. Replacing the brewing unit often is the solution.
Neye ihtiyacın var
Remove all attachments: Water tank, capsule and cup drawer, drip tray.
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
VauWeh dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
5 Yorum
Hallo schönen guten Tag ich habe Problem mit meine Gran Maestria Espressomaschine... habe einen neuen Brühkopf eingebaut wie komme ich an den Wasserschlauch in der Maschine..mfg
Hallo ich habe Problem mit meinen Nespresso-Maschine gran Maestria.. habe den Brühkopf neu ausgetauscht wie komme ich an den Wasserschlauch dran
Brilliant! A very helpful guide and essential to have the ifixit special tools. Two points - the inner coffee spout is easier to remove once the brewing unit has been unscrewed (Steps 13 + 14). Also, suggect the the inner coffee spout is cleaned before replacing as it can often be partially blocked which can lead to leaks.
It can often be difficult finding the correct brewing unit (my machine was a KRUPS) - obviously the manufacturers try to make it difficult for you!
Hi, great guide thanks. When I cleaned the brewing unit a small piece fell, and I don’t know where it belongs. A small black piece with a spring and a sort of cylindrical joint. Does anyone know where this goes?
