Ana içeriğe geç
Nest Cam Motherboard Replacement
  1. Nest Cam Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: adım 2, 3 resimden 1. Nest Cam Motherboard Replacement: adım 2, 3 resimden 2. Nest Cam Motherboard Replacement: adım 2, 3 resimden 3.
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: adım 3, 2 resimden 1. Nest Cam Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: adım 4, 3 resimden 1. Nest Cam Motherboard Replacement: adım 4, 3 resimden 2. Nest Cam Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Khiry Jones
156 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G1
7 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
where can I get a MoBo for my drop cam?
mikelebp1 - Yanıt
where can i find a motherboard replacement?
Steve - Yanıt
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Yanıt
same here, no where to be found online
chantalder - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 23,986
