Ana içeriğe geç
Nest Cam Motherboard Replacement
Neye ihtiyacın var
  1. Nest Cam Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: adım 2, 3 resimden 1. Nest Cam Motherboard Replacement: adım 2, 3 resimden 2. Nest Cam Motherboard Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: adım 3, 2 resimden 1. Nest Cam Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
    Can you show how to put this piece back?
    Eddie Carbajal - Yanıt
  4. Nest Cam Motherboard Replacement: adım 4, 3 resimden 1. Nest Cam Motherboard Replacement: adım 4, 3 resimden 2. Nest Cam Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
    Can't find a replaceement motherboard anywhere! Maybe not supposed to be replaced. Bruceontheweb@gmail.com
    Bruce Weissman - Yanıt
    Yes where can you find a motherboard for this?
    Erica - Yanıt
    Has anyone found replacement motherboards yet??
    Mike - Yanıt
    Buy a motherboard?…where…link?
    John - Yanıt
    I have broken my best cams down before to give custom paint jobs for each room. I have been trying to figure out what the button is right next to the Mic’s black and red wire female port. Is it reset? And does anyone know if it has usage info? Like press twice hold 15 sec to perform different functions? I know when trouble shooting with google support they always had me stick a paper clip in the mic holes of each one to reset, effectively destroying each mic in the process. Also seeing this posted on forums, conspiracy? Just kidding, but the button, any details?
    Deleted User - Yanıt
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Khiry Jones
159 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G1
7 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
where can I get a MoBo for my drop cam?
mikelebp1 - Yanıt
where can i find a motherboard replacement?
Steve - Yanıt
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Yanıt
same here, no where to be found online
chantalder - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 24,713
