Ana içeriğe geç
Nest Cam Side Snap Locks Replacement
Neye ihtiyacın var
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: adım 1, 1 resimden 1.
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: adım 2, 3 resimden 1. Nest Cam Side Snap Locks Replacement: adım 2, 3 resimden 2. Nest Cam Side Snap Locks Replacement: adım 2, 3 resimden 3.
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: adım 3, 3 resimden 1. Nest Cam Side Snap Locks Replacement: adım 3, 3 resimden 2. Nest Cam Side Snap Locks Replacement: adım 3, 3 resimden 3.
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: adım 4, 2 resimden 1. Nest Cam Side Snap Locks Replacement: adım 4, 2 resimden 2.
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
Sonuç
Lisa Langley
207 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G1
7 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 1,989
