Ana içeriğe geç
Nest Cam Speaker Replacement
Neye ihtiyacın var
  1. Nest Cam Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: adım 2, 1 resimden 1.
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: adım 3, 3 resimden 1. Nest Cam Speaker Replacement: adım 3, 3 resimden 2. Nest Cam Speaker Replacement: adım 3, 3 resimden 3.
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jade Weiss
662 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G1
7 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
where can I buy the new replacement speaker part?
Bradley Kang - Yanıt
Anyone find out the answer to Bradley's question?
Ravi - Yanıt
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - Yanıt
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 2,666
