Ana içeriğe geç
Nest Dropcam Pro Camera Lens Replacement
Neye ihtiyacın var
    1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: adım 1, 1 resimden 1.
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Dropcam Pro Camera Lens Replacement: adım 2, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 2, 2 resimden 2.
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Dropcam Pro Camera Lens Replacement: adım 3, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 3, 2 resimden 2.
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      FixBot'a Sor
      Yorum Ekle
    1. Nest Dropcam Pro Camera Lens Replacement, Motherboard: adım 4, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement, Motherboard: adım 4, 2 resimden 2.
      • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Dropcam Pro Camera Lens Replacement: adım 5, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 5, 2 resimden 2.
      • Pull the motherboard away from the back case.
      • Unplug the red and black cable connecting the motherboard to the back case.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Dropcam Pro Camera Lens Replacement: adım 6, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 6, 2 resimden 2.
      • Using a Philips #0 screwdriver, remove the four 2 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nest Dropcam Pro Camera Lens Replacement: adım 7, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 7, 2 resimden 2.
      • Lift the lens and LED assembly away from the motherboard.
      • Unplug the yellow and white cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: adım 8, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: adım 8, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 2. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 3.
      • Peel off the paper seal holding the Lens and LEDs together.
      • Disconnect the red and white wire from the bottom board.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Dropcam Pro Camera Lens Replacement: adım 10, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 10, 2 resimden 2.
      • Lift up the foam cover to reveal a second screw underneath.
      • Using a Philips #0 screwdriver, remove the two 3 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nest Dropcam Pro Camera Lens Replacement: adım 11, 1 resimden 1.
      • With the screws gone, lift the camera lens away from the remaining components.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Foens
896 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G4
3 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do you get replacement lens?
Jim Fischer - Yanıt Paylaş
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 4,332
