Ana içeriğe geç
Nest Dropcam Pro Camera Lens Replacement
Neye ihtiyacın var
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: adım 1, 1 resimden 1.
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Camera Lens Replacement: adım 2, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 2, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Camera Lens Replacement: adım 3, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 3, 2 resimden 2.
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: adım 4, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement, Motherboard: adım 4, 2 resimden 2.
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Camera Lens Replacement: adım 5, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 5, 2 resimden 2.
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Camera Lens Replacement: adım 6, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 6, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Camera Lens Replacement: adım 7, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 7, 2 resimden 2.
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: adım 8, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: adım 8, 2 resimden 2.
  9. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 2. Nest Dropcam Pro Camera Lens Replacement: adım 9, 3 resimden 3.
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro Camera Lens Replacement: adım 10, 2 resimden 1. Nest Dropcam Pro Camera Lens Replacement: adım 10, 2 resimden 2.
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. Nest Dropcam Pro Camera Lens Replacement: adım 11, 1 resimden 1.
    • With the screws gone, lift the camera lens away from the remaining components.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Foens
896 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G4
3 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do you get replacement lens?
Jim Fischer - Yanıt Paylaş
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 4,150
