Ana içeriğe geç
Nest Dropcam Pro Micro-USB Port Replacement
Neye ihtiyacın var
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: adım 1, 1 resimden 1.
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: adım 2, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement: adım 2, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: adım 3, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement: adım 3, 2 resimden 2.
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: adım 4, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: adım 4, 2 resimden 2.
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: adım 5, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement: adım 5, 2 resimden 2.
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: adım 6, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement: adım 6, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: adım 7, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement: adım 7, 2 resimden 2.
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: adım 8, 2 resimden 1. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: adım 8, 2 resimden 2.
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
David Foens
896 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G4
3 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - Yanıt Paylaş
Did it work for you?
Michael Candy - Paylaş
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - Yanıt Paylaş
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 32
Her zaman: 6,216
