Ana içeriğe geç
Nest Dropcam Pro Motherboard Replacement
Neye ihtiyacın var
    1. Nest Dropcam Pro Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Dropcam Pro Motherboard Replacement: adım 2, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement: adım 2, 2 resimden 2.
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Dropcam Pro Motherboard Replacement: adım 3, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement: adım 3, 2 resimden 2.
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      FixBot'a Sor
      Yorum Ekle
    1. Nest Dropcam Pro Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
      • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Dropcam Pro Motherboard Replacement: adım 5, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement: adım 5, 2 resimden 2.
      • Pull the motherboard away from the back case.
      • Unplug the red and black cable connecting the motherboard to the back case.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Dropcam Pro Motherboard Replacement: adım 6, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement: adım 6, 2 resimden 2.
      • Using a Philips #0 screwdriver, remove the four 2 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nest Dropcam Pro Motherboard Replacement: adım 7, 2 resimden 1. Nest Dropcam Pro Motherboard Replacement: adım 7, 2 resimden 2.
      • Lift the lens and LED assembly away from the motherboard.
      • Unplug the yellow and white cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
David Foens
896 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G4
3 Üyeler
36 adet Kılavuz yazıldı
7Kılavuz Yorumları
where we can get the mother board to replace
fercervantes - Yanıt Paylaş
I need this too
kundimberi - Yanıt Paylaş
Where can I get the motherboard
xtogamba - Yanıt Paylaş
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
Bruce Weissman - Yanıt Paylaş
searched for the MB online?? Why no mention of where to get it??
anonymous 6761 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 9,448
