Ana içeriğe geç
Nest Dropcam Pro Mounting Clips Replacement
Neye ihtiyacın var
  1. Nest Dropcam Pro Mounting Clips Replacement, Outer Case: adım 1, 1 resimden 1.
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
    FixBot'a Sor
    Yorum Ekle
  2. Nest Dropcam Pro Mounting Clips Replacement: adım 2, 2 resimden 1. Nest Dropcam Pro Mounting Clips Replacement: adım 2, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Nest Dropcam Pro Mounting Clips Replacement: adım 3, 2 resimden 1. Nest Dropcam Pro Mounting Clips Replacement: adım 3, 2 resimden 2.
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    FixBot'a Sor
    Yorum Ekle
  4. Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: adım 4, 2 resimden 1. Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: adım 4, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
    FixBot'a Sor
    Yorum Ekle
  5. Nest Dropcam Pro Mounting Clips Replacement: adım 5, 1 resimden 1.
    • Lift the mounting clips away from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
David Foens
896 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,547
