Ana içeriğe geç
Nest Hello Button Replacement
Neye ihtiyacın var
  1. Nest Hello Button Replacement, Casing and Faceplate: adım 1, 1 resimden 1.
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
    FixBot'a Sor
    Yorum Ekle
  2. Nest Hello Button Replacement: adım 2, 2 resimden 1. Nest Hello Button Replacement: adım 2, 2 resimden 2.
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
    FixBot'a Sor
    Yorum Ekle
  3. Nest Hello Button Replacement: adım 3, 3 resimden 1. Nest Hello Button Replacement: adım 3, 3 resimden 2. Nest Hello Button Replacement: adım 3, 3 resimden 3.
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
    FixBot'a Sor
    Yorum Ekle
  4. Nest Hello Button Replacement, Motherboard: adım 4, 1 resimden 1.
    • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
    FixBot'a Sor
    Yorum Ekle
  5. Nest Hello Button Replacement: adım 5, 2 resimden 1. Nest Hello Button Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Grip the connector with the tweezers as shown and pull it away from the casing.
    FixBot'a Sor
    Yorum Ekle
  6. Nest Hello Button Replacement: adım 6, 1 resimden 1.
    • Remove the six smaller screws shown with the Phillips #000 screwdriver.
    • Remove the three larger screws shown with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Nest Hello Button Replacement: adım 7, 2 resimden 1. Nest Hello Button Replacement: adım 7, 2 resimden 2.
    • Holding the device as shown push the circuit board away from you and up to free it from the clips.
    FixBot'a Sor
    Yorum Ekle
  8. Nest Hello Button Replacement: adım 8, 2 resimden 1. Nest Hello Button Replacement: adım 8, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
    FixBot'a Sor
    Yorum Ekle
  9. Nest Hello Button Replacement: adım 9, 1 resimden 1.
    • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
    • Work your way around the device, prying the circuit board away from the housing.
    • Make sure to feed the wires when taking off the circuit board.
    FixBot'a Sor
    Yorum Ekle
    • Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Ryan Gauder - Yanıt Paylaş
Where do I buy a button?
Joel Lundi - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 69
Her zaman: 4,164
