Ana içeriğe geç
Nest Hello Camera Replacement
Neye ihtiyacın var
    1. Nest Hello Camera Replacement, Casing and Faceplate: adım 1, 1 resimden 1.
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Hello Camera Replacement: adım 2, 2 resimden 1. Nest Hello Camera Replacement: adım 2, 2 resimden 2.
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Hello Camera Replacement: adım 3, 3 resimden 1. Nest Hello Camera Replacement: adım 3, 3 resimden 2. Nest Hello Camera Replacement: adım 3, 3 resimden 3.
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      FixBot'a Sor
      Yorum Ekle
    1. Nest Hello Camera Replacement, Motherboard: adım 4, 1 resimden 1.
      • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Hello Camera Replacement: adım 5, 2 resimden 1. Nest Hello Camera Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Grip the connector with the tweezers as shown and pull it away from the casing.
      FixBot'a Sor
      Yorum Ekle
    3. Nest Hello Camera Replacement: adım 6, 1 resimden 1.
      • Remove the six smaller screws shown with the Phillips #000 screwdriver.
      • Remove the three larger screws shown with the Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Nest Hello Camera Replacement: adım 7, 2 resimden 1. Nest Hello Camera Replacement: adım 7, 2 resimden 2.
      • Holding the device as shown push the circuit board away from you and up to free it from the clips.
      FixBot'a Sor
      Yorum Ekle
    5. Nest Hello Camera Replacement: adım 8, 2 resimden 1. Nest Hello Camera Replacement: adım 8, 2 resimden 2.
      • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
      FixBot'a Sor
      Yorum Ekle
    6. Nest Hello Camera Replacement: adım 9, 1 resimden 1.
      • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
      • Work your way around the device, prying the circuit board away from the housing.
      • Make sure to feed the wires when taking off the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. Nest Hello Camera Replacement, Camera: adım 10, 3 resimden 1. Nest Hello Camera Replacement, Camera: adım 10, 3 resimden 2. Nest Hello Camera Replacement, Camera: adım 10, 3 resimden 3.
      • Remove the plug connecting the camera to the device.
      FixBot'a Sor
      Yorum Ekle
    2. Nest Hello Camera Replacement: adım 11, 3 resimden 1. Nest Hello Camera Replacement: adım 11, 3 resimden 2. Nest Hello Camera Replacement: adım 11, 3 resimden 3.
      • Lift the top layer of circuits to reveal the unplugged camera.
      • Lift up the camera and remove it from the device.
      • If you flip the camera upside down a black rubber rectangle will fall out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 39
Her zaman: 2,867
