Ana içeriğe geç
Nest Hello O-Ring Replacement
Neye ihtiyacın var
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: adım 1, 1 resimden 1.
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello O-Ring Replacement: adım 2, 2 resimden 1. Nest Hello O-Ring Replacement: adım 2, 2 resimden 2.
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello O-Ring Replacement: adım 3, 3 resimden 1. Nest Hello O-Ring Replacement: adım 3, 3 resimden 2. Nest Hello O-Ring Replacement: adım 3, 3 resimden 3.
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello O-Ring Replacement, O-Ring: adım 4, 1 resimden 1.
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - Yanıt
Also looking for this replacement part. Googling did not produce results.
KB_KB - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 115
Her zaman: 3,960
