Ana içeriğe geç
Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement
Neye ihtiyacın var
  1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: adım 1, 2 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: adım 1, 2 resimden 2.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Open Display: adım 2, 1 resimden 1.
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: adım 3, 2 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: adım 3, 2 resimden 2.
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 3.
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: adım 5, 2 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 2.
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: adım 7, 3 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: adım 7, 3 resimden 2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: adım 7, 3 resimden 3.
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Locate auto-away sensor: adım 8, 1 resimden 1.
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: adım 9, 2 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: adım 9, 2 resimden 2.
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: adım 10, 3 resimden 1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: adım 10, 3 resimden 2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: adım 10, 3 resimden 3.
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Curry
264 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G5
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,284
