Giriş
When replacing the base motherboard, removal from the wall is necessary and power to the thermostat must be turned off. The tools required are the blue opening tools, spudger, and a #0 Phillips screwdriver.
Neye ihtiyacın var
Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
HOW do you disconnect the wires? I can't get them out!
Same here. It is like the springs are in a stuck position
I also can not dis-engage the wires. Feels like the springs are frozen closed.
Yes, the button on the end of the wires is stuck in the down position. Tried pushing with my fingers and several smaller tools- they appear to be frozen in the down position.
Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
Unsnap the base from the trim plate (if used) using a plastic opening tool.
Turn the base over.
Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
Pry the base mother board open from the side using a plastic opening tool.
Pry the baseboard from the bottom using the flat end of a spudger.
6 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Where can we purchase replacement parts?
i want the baseboard.. where i can buy? pls help...
I have no clue why people like their thermostats to the degree that they do.. I am both an A/c professional and an Engineer. They use what is called an SCR or silicon controlled rectifier for their switching instead of a tiny relay. An SCR is very sensitive to a spark or voltage spike. Yes the thermostat is pretty cool and has some nice features. It is advanced electronics but using SMC's or Surface Mounted Components?? . Maybe that would work well in a shielded component. But NOT in something that is connected to long external wires. The consumer bought warranty is only one year. I have seen too many issues in the field with their overpriced toys. Not having parts for this Chinese made thermostat? Priceless.
Hey Jon, I’m trying to repair my parent’s 2nd Gen Nest. It sends out “heat” and “cool” signal at the same time. Anyway I can replace a component on the motherboard?
Lizik -
Good post. Wish I had read before I got a Nest thermostat. What would you recommend as a good alternative? I hate when you can't replace simple components and parts cheaply and quickly. What the !&&*.
