Ana içeriğe geç
Nest Learning Thermostat 2nd Generation Battery Replacement
Neye ihtiyacın var
  1. Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: adım 1, 2 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: adım 1, 2 resimden 2.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Battery Replacement, Open Display: adım 2, 1 resimden 1.
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: adım 3, 2 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: adım 3, 2 resimden 2.
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 2. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 3.
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: adım 5, 2 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 2.
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: adım 7, 3 resimden 1. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: adım 7, 3 resimden 2. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: adım 7, 3 resimden 3.
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
Sonuç
44 farklı kişi bu kılavuzu tamamladı.
Dustinluckenbill
703 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G5
5 Üyeler
12 adet Kılavuz yazıldı
15Kılavuz Yorumları
It should be noted that doing this will void the warranty on your device. If you are having issues with the display battery you should call the tech support line and they will help you. Doing this risk damaging the device and making it to where they will not replace it if it is still under warranty.
Bob bobbado - Yanıt
ON MY NEST WHEN YOU "pull 2"...IT WAS GLUED TO THE METAL TOP OP THE MOTHERBOARD UNDERNEATH...SO IF THIS IS THE CASE BE VERY CAREFUL AS YOU DISLODGE THE BATTERY ....ALSO THE PLUG FOR THE BATTERY WAS TAPED DOWN WITH AMBER COLORED TAPE WHICH I HAD TO REMOVE BEFORE I WAS ABLE TO UNPLUG THE BATTERY...I REPLACED THE TAPE WITH SOME SCOTCH TAPE AFTER REINSTALLING THE BATTERY...ALL IN ALL...GOO INSTRUCTIONS...A FIVE MINUTE FIX !!!
Andrew Jordan - Yanıt
I also am having a time finding the replacement battery
Brian wilson -
I am having trouble locating a replacement battery. Any idea where to look?
Ron Temaat - Yanıt
As of 12/28/17 this website has replacement batteries for $12 plus shipping:
www.batteryclerk.com
Here’s a direct link to the Gen1 battery page which has a link to the Gen2 battery page
http://www.batteryclerk.com/products/nes...
Ron Saritzky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 135
Son 30 gün: 682
Her zaman: 178,363
