Ana içeriğe geç
Nest Learning Thermostat 2nd Generation LCD Screen Replacement
Neye ihtiyacın var
  1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: adım 1, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: adım 1, 2 resimden 2.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
    FixBot'a Sor
  2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Open Display: adım 2, 1 resimden 1.
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
    FixBot'a Sor
  3. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: adım 3, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: adım 3, 2 resimden 2.
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
    FixBot'a Sor
  4. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: adım 4, 3 resimden 3.
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
    FixBot'a Sor
  5. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: adım 5, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
    FixBot'a Sor
  6. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: adım 6, 2 resimden 2.
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
    FixBot'a Sor
  7. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: adım 7, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: adım 7, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: adım 7, 3 resimden 3.
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
    FixBot'a Sor
  8. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Locate auto-away sensor: adım 8, 1 resimden 1.
    • Locate the auto-away sensor.
    FixBot'a Sor
  9. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: adım 9, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: adım 9, 2 resimden 2.
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
    FixBot'a Sor
  10. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: adım 10, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: adım 10, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: adım 10, 3 resimden 3.
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
    FixBot'a Sor
  11. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screw from motherboard: adım 11, 1 resimden 1.
    • Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
    FixBot'a Sor
  12. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: adım 12, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: adım 12, 2 resimden 2.
    • Remove the EMI shield from the motherboard using the plastic opening tools.
    FixBot'a Sor
  13. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: adım 13, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: adım 13, 2 resimden 2.
    • Unsnap the LCD ribbon from the motherboard gently using the tweezers.
    FixBot'a Sor
  14. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: adım 14, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: adım 14, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: adım 14, 3 resimden 3.
    • Locate the black tabs that hold the display to the motherboard.
    • Push the black tabs gently away from the motherboard using the plastic opening tools.
    FixBot'a Sor
  15. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: adım 15, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: adım 15, 2 resimden 2.
    • Pull the face display gently away from the motherboard.
    FixBot'a Sor
  16. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: adım 16, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: adım 16, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: adım 16, 3 resimden 3.
    • The front of the glass display and plastic frame is held together by only light adhesive.
    • Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
    FixBot'a Sor
  17. Nest Learning Thermostat 2nd Generation LCD Screen Replacement: adım 17, 1 resimden 1.
    • Pry the front glass and plastic frame apart gently using the plastic opening tools.
    FixBot'a Sor
  18. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: adım 18, 2 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: adım 18, 2 resimden 2.
    • Pry the LCD screen gently from the plastic frame using the plastic opening tools.
    FixBot'a Sor
  19. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: adım 19, 3 resimden 1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: adım 19, 3 resimden 2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: adım 19, 3 resimden 3.
    • Pull the LCD screen away from the plastic frame gently using your fingers.
    FixBot'a Sor
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Justin Curry
264 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G5
5 Üyeler
12 adet Kılavuz yazıldı
5Kılavuz Yorumları
Please could you say the type of LCD screen? Or present detailed photo of rear side?
vladvys - Yanıt Paylaş
Yes, this is a guide for replacing the LCD. I'd like to know what LCD to order. Thanks.
kylegoetz - Yanıt Paylaş
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
erick.starke - Yanıt Paylaş
Skip step 12. There is no reason to remove the EMI shield.
richardrobison - Yanıt Paylaş
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
Stan Griff - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 102
Her zaman: 16,728
