Ana içeriğe geç
Nest Thermostat E Motherboard Replacement
Neye ihtiyacın var
  1. Nest Thermostat E Motherboard Replacement, Base Plate: adım 1, 1 resimden 1.
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Motherboard Replacement: adım 3, 1 resimden 1.
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
    • Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
  5. Nest Thermostat E Motherboard Replacement: adım 5, 2 resimden 1. Nest Thermostat E Motherboard Replacement: adım 5, 2 resimden 2.
    • Flip the base display over and the display motherboard will remove itself from the display.
Sonuç
Andrew Ahlborn
368 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 342
