Giriş
How to remove the plastic housing of the camera to either replace it, or remove it to get to the internals of the camera.
Neye ihtiyacın var
Locate unlock switch on underside of camera and unlock it by sliding it.
Once unlocked, slide the cover out and up to open the battery housing.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
