Ana içeriğe geç
Netgear WGR614v9 Capacitor Replacement
Neye ihtiyacın var
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: adım 1, 1 resimden 1.
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: adım 2, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 2, 2 resimden 2.
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: adım 3, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 3, 2 resimden 2.
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: adım 4, 1 resimden 1.
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: adım 6, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 6, 2 resimden 2.
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: adım 7, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement, Capacitor: adım 7, 2 resimden 2.
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: adım 8, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 8, 2 resimden 2.
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: adım 9, 2 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 9, 2 resimden 2.
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: adım 10, 3 resimden 1. Netgear WGR614v9 Capacitor Replacement: adım 10, 3 resimden 2. Netgear WGR614v9 Capacitor Replacement: adım 10, 3 resimden 3.
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Moore
95 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G24
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 3,199
