Ana içeriğe geç
Netgear WGR614v9 Lower Case Replacement
Neye ihtiyacın var
  1. Netgear WGR614v9 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Lower Case Replacement: adım 2, 2 resimden 1. Netgear WGR614v9 Lower Case Replacement: adım 2, 2 resimden 2.
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Lower Case Replacement: adım 3, 2 resimden 1. Netgear WGR614v9 Lower Case Replacement: adım 3, 2 resimden 2.
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Lower Case Replacement: adım 4, 1 resimden 1.
    • Lift the bottom casing straight up from the router.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Murphy
488 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G24
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,614
