Ana içeriğe geç
Netgear WGR614v9 Motherboard Replacement
Neye ihtiyacın var
  1. Netgear WGR614v9 Motherboard Replacement, Lower Case: adım 1, 1 resimden 1.
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Motherboard Replacement: adım 2, 2 resimden 1. Netgear WGR614v9 Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Motherboard Replacement: adım 3, 2 resimden 1. Netgear WGR614v9 Motherboard Replacement: adım 3, 2 resimden 2.
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Motherboard Replacement: adım 6, 2 resimden 1. Netgear WGR614v9 Motherboard Replacement: adım 6, 2 resimden 2.
    • Separate the motherboard from the top shell by lifting it straight up from the router.
Sonuç
Ryan Murphy
488 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G24
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,207
