Neye ihtiyacın var
Remove the screw with a Philips J1 driver.
Try to remove the cables by hand or if you really can't, then use a spudger to carefully pry them up.
After removing the screw and the cables, you can safely remove the network card.
Bir başkası bu kılavuzu tamamladı.
