Ana içeriğe geç
Network card Replacement
Neye ihtiyacın var
  1. Network card Replacement, Remove battery: adım 1, 1 resimden 1.
    • Be sure to remove the battery to prevent any electrical shortage.
    FixBot'a Sor
    Yorum Ekle
  2. Network card Replacement, Remove the backpanel: adım 2, 2 resimden 1. Network card Replacement, Remove the backpanel: adım 2, 2 resimden 2.
    • Loosen all four screws and remove the back panel.
    • Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Network card Replacement, Remove the antenna wires: adım 3, 2 resimden 1. Network card Replacement, Remove the antenna wires: adım 3, 2 resimden 2.
    • In the red circle is the network card
    • Remove the two wires (inside the green circle)
    • the wires are very fragile and need to be removed with care
    FixBot'a Sor
    Yorum Ekle
  4. Network card Replacement, Remove the network card: adım 4, 1 resimden 1.
    • Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
    • The wires are very fragile, be aware!
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Be sure to connect the wires the same as in step 3.
2 farklı kişi bu kılavuzu tamamladı.
Robin Koch
289 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,116
