Ana içeriğe geç
NeuTab N7 Pro Camera Replacement
Neye ihtiyacın var
    1. NeuTab N7 Pro Camera Replacement, Camera: adım 1, 1 resimden 1.
      • Power off your device before beginning disassembly
      • Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
      FixBot'a Sor
      Yorum Ekle
    2. NeuTab N7 Pro Camera Replacement: adım 2, 1 resimden 1.
      • Locate the camera unit and note where it is attached to the motherboard.
      • Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
      • Metal tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
      FixBot'a Sor
      Yorum Ekle
    3. NeuTab N7 Pro Camera Replacement: adım 3, 2 resimden 1. NeuTab N7 Pro Camera Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
      • Carefully pull the ribbon cable out, removing the camera from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 7-1, Cheng Spring 2016 USF Tampa, Team 7-1, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G1
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 531
