Giriş
This guide will provide a detailed step-by-step instructions on how to replace the power cord for the KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70). Additionally, a lot of work was put into ensuring that this guide applies for all voltage/frequency variants of these models (e.g., 5KSM70, 7KSM55, etc.) and all plug types.
NOTE: The 7.0-quart modes (KSM70) are notably different from the ProLine 7.0-quart models (Models KSM7XXX, where XXX is a three-digit number, e.g. KSM7586).
As different locations can use not only different voltages/frequencies but also different plugs, there are a number of permutations across these combinations and model numbers. Use the following table to determine the appropriate Whirlpool Part Number for your power cord:
Location | KSM55 | KSM60 | KSM70 |
Americas (USA/Canada/Central America/Some of South America) | W11459236 | W11459236 | W11459266 |
Argentina/Chile/Peru | Not Released Yet | W11459245 | W11459275 |
Australia/New Zealand | W11459243 | W11459243 | W11459273 |
Brasil - 127V version only | Not Released Yet | W11459238 | W11459268 |
Europe/Middle East/Africa/Asia | W11459240 | W11459240 | W11459270 |
India | W11459247 | Not Released Yet | W11459277 |
UK | W11459249 | W11459249 | W11459279 |
Neye ihtiyacın var
Place some dish towels or other soft material in the base to protect it from any potential impact.
Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
Remove the trim band.
Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
Remove the cover by lifting it straight up.
Using the T25 Torx Screwdriver, remove the four torx screws by the powertrain (circled in yellow, two on each side)
Remove the hall effect sensor from its mount by pressing down on the tab indicated in the first picture and sliding it out.
Disconnect the power cable by holding down the clip on the right side of the plug and pulling the plug straight up.
The powertrain is comprised of the motor, the gearbox, and the transfer gears. Unlike previous generations of KitchenAid AC Motor bowl-lift mixers, which had these broken in to discrete parts, this is a single unit.
Using a #2 Philips screwdriver, remove the four screws (circled in yellow, two on each side) attaching the powertrain to the mixer body.
Remove the powertrain/motor, placing it to the side in a safe location where it can't get damaged.
Using a #2 Philips screwdriver, remove the two screws (circled in yellow in the first image) holding the speed/motor control assembly to the mixer body.
Pivot the assembly up to reveal the power connector (circled in blue in the second image).
Remove the power connector by depressing the tab on the edge of the connector (circled in green in the third image) and pulling upwards.
Using a #2 Philips screwdriver, remove the screw (circled in yellow) which attached the ground lead to the mixer body.
Remove the power cord by lifting up at the strain relief where it passes into the mixer.
Bir başkası bu kılavuzu tamamladı.
