Ana içeriğe geç
New Nintendo 3DS XL 2015 Game Card Reader Replacement
Neye ihtiyacın var
  1. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 2, 1 resimden 1.
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 3, 1 resimden 1.
    • Once the screws are loosened, pry open the back cover.
  4. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 4, 1 resimden 1.
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
  5. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Motherboard: adım 5, 1 resimden 1.
    • Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  6. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 6, 2 resimden 1. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 6, 2 resimden 2.
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  7. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 7, 3 resimden 1. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 7, 3 resimden 2. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 7, 3 resimden 3.
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  8. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 8, 1 resimden 1.
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  9. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 9, 1 resimden 1.
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
    • Slide the ribbon out of the ZIF connector.
  10. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 10, 1 resimden 1.
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  11. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 11, 1 resimden 1.
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  12. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 12, 1 resimden 1.
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  13. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 13, 3 resimden 1. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 13, 3 resimden 2. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 13, 3 resimden 3.
    • Using tweezers, gently pull the five marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them! Note that in some models the upper-most connector may have a lock.
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  14. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 14, 1 resimden 1.
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  15. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 15, 2 resimden 1. New Nintendo 3DS XL 2015 Game Card Reader Replacement: adım 15, 2 resimden 2.
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different.
  16. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Game Card Reader: adım 16, 1 resimden 1.
    • Remove five 5mm screws from the game card reader panel using a JIS #000 screwdriver.
    • The game card reader can now be removed and replaced.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Jacky Loh
338 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-4, Lancaster Spring 2015 Cal Poly, Team 24-4, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G4
4 Üyeler
25 adet Kılavuz yazıldı
9 Yorum
I bought a replacement card slot and it has the small flat cable connector not on the top right like on your photos (and in my New 3DS XL) but on the right oriented to the right, see https://abload.de/img/cardslot_sintech_2....
Does anyone have any insight on different revisions of the card slot? Where can I buy a card slot like the one in the photos here? Thanks in advance.
Uwe - Yanıt
Will I be able to complete this process with a PH00? I don’t have have a PH000 or any JIS screwdrivers.
Luke - Yanıt
You don't have to take the entire board out to replace this
Skyler Davis - Yanıt
Are you sure?
Kevin Canto -
That is true. I just changed mine easily without removing the whole mainboard..
battlepengu -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 111
Son 30 gün: 459
Her zaman: 36,738
