Ana içeriğe geç
Newport e360 Exhalation Flow Sensor Replacement
Neye ihtiyacın var
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: adım 1, 1 resimden 1.
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
    FixBot'a Sor
    Yorum Ekle
  2. Newport e360 Exhalation Flow Sensor Replacement: adım 2, 1 resimden 1.
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
    FixBot'a Sor
    Yorum Ekle
  3. Newport e360 Exhalation Flow Sensor Replacement: adım 3, 1 resimden 1.
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
    FixBot'a Sor
    Yorum Ekle
  4. Newport e360 Exhalation Flow Sensor Replacement: adım 4, 1 resimden 1.
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
    FixBot'a Sor
    Yorum Ekle
  5. Newport e360 Exhalation Flow Sensor Replacement: adım 5, 1 resimden 1.
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
    FixBot'a Sor
    Yorum Ekle
  6. Newport e360 Exhalation Flow Sensor Replacement: adım 6, 1 resimden 1.
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lauren Ochoa
192 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G21, Paton Spring 2020 Cal Poly, Team S7-G21, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G21
3 Üyeler
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Yanıt Paylaş
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 857
