Giriş
If you need to replace the air and oxygen flow sensors on the newport e500 you will need to start with the prerequisites for this operation. You will need a medium and small sized Philips screwdriver and a torque wrench. For more information refer to page 59 of the service manual.
Note: When reinstalling flow sensors, note whether the sensor is labeled for air or oxygen and be sure to install in the appropriate position.
Neye ihtiyacın var
Place device so that the top cover is facing you.
Open the top cover.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Remove the 2 screws and washers securing the manifold/mixer assembly
