Ana içeriğe geç
Newport e500 Internal Battery Disassembly
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Newport e500 Internal Battery  Disassembly, Newport e500 Top Cover Disassembly: adım 1, 1 resimden 1.
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Internal Battery  Disassembly: adım 2, 1 resimden 1.
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Internal Battery  Disassembly: adım 3, 1 resimden 1.
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Internal Battery  Disassembly, Newport e500 Exhalation Module Disassembly: adım 4, 1 resimden 1.
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  5. Newport e500 Internal Battery  Disassembly: adım 5, 1 resimden 1.
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  6. Newport e500 Internal Battery  Disassembly: adım 6, 1 resimden 1.
    • Pull the exhalation module straight up to remove it from the GDU.
  7. Newport e500 Internal Battery  Disassembly, Newport e500 Internal Battery  Disassembly: adım 7, 1 resimden 1.
    • Remove the two nuts that hold the battery cover to the electronics box assembly and remove the cover.
  8. Newport e500 Internal Battery  Disassembly: adım 8, 1 resimden 1.
    • Disconnect the black and red wires from the battery terminals.
  9. Newport e500 Internal Battery  Disassembly: adım 9, 1 resimden 1.
    • Pull the battery from the electronics box assembly.
Sonuç
Jeremy
589 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G16, Paton Spring 2020 Cal Poly, Team S7-G16, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G16
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 134
