Ana içeriğe geç
NexTime Wall Pad Clock Movement Replacement
Neye ihtiyacın var
  1. NexTime Wall Pad Clock Movement Replacement, Clock Movement: adım 1, 1 resimden 1.
    • Place the clock face down.
    • Remove the battery.
  2. NexTime Wall Pad Clock Movement Replacement: adım 2, 2 resimden 1. NexTime Wall Pad Clock Movement Replacement: adım 2, 2 resimden 2.
    • Turn the brown gear clockwise until both the minute and hour hands align.
  3. NexTime Wall Pad Clock Movement Replacement: adım 3, 2 resimden 1. NexTime Wall Pad Clock Movement Replacement: adım 3, 2 resimden 2.
    • Use a pair of pliers to pull out the cap.
  4. NexTime Wall Pad Clock Movement Replacement: adım 4, 2 resimden 1. NexTime Wall Pad Clock Movement Replacement: adım 4, 2 resimden 2.
    • Pull out the minute hand using your fingers.
  5. NexTime Wall Pad Clock Movement Replacement: adım 5, 2 resimden 1. NexTime Wall Pad Clock Movement Replacement: adım 5, 2 resimden 2.
    • Pull out the hour hand using your fingers.
  6. NexTime Wall Pad Clock Movement Replacement: adım 6, 3 resimden 1. NexTime Wall Pad Clock Movement Replacement: adım 6, 3 resimden 2. NexTime Wall Pad Clock Movement Replacement: adım 6, 3 resimden 3.
    • Find the two ridges on the washer.
    • Use a pair of pliers to screw the washer out with a counter clockwise motion.
    • Use your fingers to remove the washer.
  7. NexTime Wall Pad Clock Movement Replacement: adım 7, 1 resimden 1.
    • Take out the clock movement mechanism and replace it.
Sonuç
Leo Santos
145 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
what size to by the shaf nexime
john - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 1,839
