Ana içeriğe geç
NexiGo NS32 Battery Replacement
Neye ihtiyacın var
  1. NexiGo NS32 Battery Replacement, Rear Case: adım 1, 1 resimden 1.
    • Orient the controller so that it is face down.
    FixBot'a Sor
    Yorum Ekle
  2. NexiGo NS32 Battery Replacement: adım 2, 2 resimden 1. NexiGo NS32 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the eight 9 mm Phillips screws that secure the rear case.
    FixBot'a Sor
    Yorum Ekle
  3. NexiGo NS32 Battery Replacement: adım 3, 1 resimden 1.
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
    FixBot'a Sor
    Yorum Ekle
  4. NexiGo NS32 Battery Replacement, Battery: adım 4, 2 resimden 1. NexiGo NS32 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
    FixBot'a Sor
    Yorum Ekle
  5. NexiGo NS32 Battery Replacement: adım 5, 3 resimden 1. NexiGo NS32 Battery Replacement: adım 5, 3 resimden 2. NexiGo NS32 Battery Replacement: adım 5, 3 resimden 3.
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
Do you know what model battery I would need to buy to replace the original?
Jack Dunne - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 418
