Ana içeriğe geç
Nextbook 8 Battery Replacement
Neye ihtiyacın var
  1. Nextbook 8 Battery Replacement, Battery: adım 1, 2 resimden 1. Nextbook 8 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: adım 2, 2 resimden 1. Nextbook 8 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: adım 3, 2 resimden 1. Nextbook 8 Battery Replacement: adım 3, 2 resimden 2.
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: adım 5, 2 resimden 1. Nextbook 8 Battery Replacement: adım 5, 2 resimden 2.
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
Dylan Wiese
1.889 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G1
3 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Very helpful and well made.
Quentin Freed - Yanıt Paylaş
Where can I buy the battery???
scruff67 - Yanıt Paylaş
Check Ebay. That's where I'm headed right now.
Tina Carey - Paylaş
im having connection issues i cant find any wifi period
crusher309 - Yanıt Paylaş
Hello,
Yes well, but what is th voltage battery?
Thanks
Tyeroued - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 77
Her zaman: 43,180
