Ana içeriğe geç
Nextbook 8 Screen Replacement
Neye ihtiyacın var
    1. Nextbook 8 Screen Replacement, Battery: adım 1, 2 resimden 1. Nextbook 8 Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook 8 Screen Replacement: adım 2, 2 resimden 1. Nextbook 8 Screen Replacement: adım 2, 2 resimden 2.
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook 8 Screen Replacement: adım 3, 2 resimden 1. Nextbook 8 Screen Replacement: adım 3, 2 resimden 2.
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      FixBot'a Sor
      Yorum Ekle
    4. Nextbook 8 Screen Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      FixBot'a Sor
      Yorum Ekle
    5. Nextbook 8 Screen Replacement: adım 5, 2 resimden 1. Nextbook 8 Screen Replacement: adım 5, 2 resimden 2.
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook 8 Screen Replacement, Screen: adım 6, 1 resimden 1.
      • Remove the silver and gold sticker at the bottom of the device.
      • Hold the brown circuit board down with your finger while you remove the sticker
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook 8 Screen Replacement: adım 7, 2 resimden 1. Nextbook 8 Screen Replacement: adım 7, 2 resimden 2.
      • Use a spudger to lift up the black tabs on the three ZIF connectors.
      • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook 8 Screen Replacement: adım 8, 2 resimden 1. Nextbook 8 Screen Replacement: adım 8, 2 resimden 2.
      • Remove the 5 black screws on the motherboard.
      • Carefully lift the motherboard off of the device and remove.
      FixBot'a Sor
      Yorum Ekle
    4. Nextbook 8 Screen Replacement: adım 9, 2 resimden 1. Nextbook 8 Screen Replacement: adım 9, 2 resimden 2.
      • Remove the two screws that hold the brackets in place.
      • Remove the two silver brackets that hold the screen in place.
      FixBot'a Sor
      Yorum Ekle
    5. Nextbook 8 Screen Replacement: adım 10, 2 resimden 1. Nextbook 8 Screen Replacement: adım 10, 2 resimden 2.
      • Remove the one silver screw on the small green circuit board at the bottom of the device.
      • Set aside the small circuit board for now.
      FixBot'a Sor
      Yorum Ekle
    6. Nextbook 8 Screen Replacement: adım 11, 1 resimden 1.
      • Remove the two silver screws from the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    7. Nextbook 8 Screen Replacement: adım 12, 3 resimden 1. Nextbook 8 Screen Replacement: adım 12, 3 resimden 2. Nextbook 8 Screen Replacement: adım 12, 3 resimden 3.
      • With the device face down, use a spudger to lift the screen off of the glass from the right side.
      FixBot'a Sor
      Yorum Ekle
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Dylan Wiese
1.889 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G1
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
where do I find the actual screen though
WiKiT Woo WoNKa - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 49
Her zaman: 24,468
