Ana içeriğe geç
Nextbook Flexx 10 Back Cover Replacement
Neye ihtiyacın var
  1. Nextbook Flexx 10 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Nextbook Flexx 10 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • To begin, turn off the power to the device and remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Back Cover Replacement: adım 2, 3 resimden 1. Nextbook Flexx 10 Back Cover Replacement: adım 2, 3 resimden 2. Nextbook Flexx 10 Back Cover Replacement: adım 2, 3 resimden 3.
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Back Cover Replacement: adım 3, 2 resimden 1. Nextbook Flexx 10 Back Cover Replacement: adım 3, 2 resimden 2.
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,348
