Ana içeriğe geç
Nextbook Flexx 10 Docking Port Replacement
Neye ihtiyacın var
  1. Nextbook Flexx 10 Docking Port Replacement, Back Cover: adım 1, 2 resimden 1. Nextbook Flexx 10 Docking Port Replacement, Back Cover: adım 1, 2 resimden 2.
    • To begin, turn off the power to the device and remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Docking Port Replacement: adım 2, 3 resimden 1. Nextbook Flexx 10 Docking Port Replacement: adım 2, 3 resimden 2. Nextbook Flexx 10 Docking Port Replacement: adım 2, 3 resimden 3.
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Docking Port Replacement: adım 3, 2 resimden 1. Nextbook Flexx 10 Docking Port Replacement: adım 3, 2 resimden 2.
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
  4. Nextbook Flexx 10 Docking Port Replacement, Docking Port: adım 4, 2 resimden 1. Nextbook Flexx 10 Docking Port Replacement, Docking Port: adım 4, 2 resimden 2.
    • Now, look around the outer edge in between the two speakers.
    • Locate the docking port
    • Remove the two screws holding the docking port in place with a PH0 philips head screwdriver.
  5. Nextbook Flexx 10 Docking Port Replacement: adım 5, 1 resimden 1.
    • After both screws are removed:
    • Carefully lift the black part of the connector at the board end of the gold cable.
    • Gently pull the gold cable out of the slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 919
